ORIGINAL: ArthurD
.......how do you think a Jett .50 will work out?
I had a Shrike with a SJ 50 and it was excellent. I liked the APC 9x8 but some like the 9x9. Just make sure you balance it per the instructions. The kit comes out nose heavy and it does not land/fly well that way. The standard Jett tuned muffler will probably hit the wing but an easy mod to the wing will fix that. The engine needs to be mounted as far back as possible to balance. I went to the Jett SS muffler that is a little shorter (more rpm) and it did not hit the wing.
