RE: BT Bf109E-4
back to work on the tail. i made a couple of rudder control horns from computer board. i prefer this stuff to g-10 because it's a lot easier to cut.
then i cut some slots in the rudder, added the horns and then drilled through them for some toothpick pins.
then temporarily mounted to add the pull-pull controls. with that i could add the remaining fuselage lower side pieces and bottom piece. i filled in the smaller gaps with microballoons. i'm beginning to wish i hadn't glued the horizontal stab on so soon as it would make it much easier to shape the rear end/vertical fin without the stab getting in the way.
