RE: HobbyZone Firebird Commander 2 w/ACT
Nothing as exciting as Anti-Crash Technology (ACT) has happened to entry-level radio-controlled planes since HobbyZone was introduced. Here’s how it works:
Two sensors on the fuselage, one on the top and one on the bottom, monitor the position of the plane in relation to the ground. When the plane is flying level, the top sensor sees the sky while the bottom sensor sees the ground, and they tell the onboard computer (receiver) that the plane is flying correctly. If the plane enters a severe dive, the sensors detect the change in orientation and react to the danger that the plane is then in. The software in the receiver will then temporarily cut the motor, and correct the severe angle and pitch of the plane. This causes the nose to come up and pulls the plane out of the dive to help prevent the plane from crashing. The pilot is then able to regain control. If pilots are flying correctly and do not put the plane into a severe dive situation while ACT is engaged, they will have complete control of the plane’s flight pattern. Once users gain experience flying, they can turn ACT off.
Now, you can take advantage of this technological development by purchasing a Firebird Commander 2. This plane comes with everything that you need to teach yourself how to fly, including a battery pack for the plane, batteries for the transmitter, and an instructional video and manual. All of this, including the revolutionary Anti-Crash Technology, for a very low price makes the Commander 2 an exceptional value!
