RE: Air Hogs Aero Ace!
actually they jus pull out..they are stuck on with strong sticky tape..slowly pull 1 side and it will come off the fuselage..single wing flys much better..then yiu can sand down that whole area on both sides of fusealge...with a 240 mah -1s lipo..I should easily get 20 minutes flight..if you arent happy with your range..increase the antenna with some magnet wire..stk antenna is around 15c.ms...cut one that is 60cms...and you will have all the range you need..just loop it thru the rear boom 3 times..
