Old 10-07-2005, 11:07 PM
  #31
codimasta
My Feedback: (89)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Transall C-160
This is what Castle Creations sent:
Sounds like a good project. Go with 3s lipo, total as many p as it takes
to get about 7000-8000 mah total. Have one large pack or several in
parallel with a Y harness going to the controllers. Use a Y harness to
each controller off of you receiver throttle channel. Set the the
controllers to Cut of Type = 'Soft Cut Off', Throttle Type = 'Fixed' as
Soft Start = 'Softest'. Phoenix 35s would good in this application.
Don't be afraid to go up in ESC capacity but don't go down.
If you have any other questions don't hesitate to ask.
Cordially,
Bernie Wolfard AMA# 7712
Product Support Specialist
Castle Creations
402 E Pendleton
Wellsville, KS 66092
785-883-4519, Ext 123
berniew@castlecreations.com
> Subject:
> Conversion
> From:
> Lawrence Paiva <paiv@wizard.com>
> Date:
> Fri, 22 Jul 2005 12:21:05 -0700
> To:
> support@castlecreations.com
> To:
> I am presently in the process of converting an Transall C-160 Model
> from glow to electric.
> Wingspan: 73.3 in. Wing Area: 605 sq. in. Flying weight:
> 6.4 lbs Engines: 2ea. .25 cu in.
> Planing to use: AXI 2814/10 Brushless motor (2 ea.) Prop: 9-6 to 10-6
> 3 s 2 p Lipoly..X 2 per motor 11.1v 4000
> ma or Should it be 4 s 2p 14.8 4000 ma.
> Brushless Contorller: Phoenix - 35 X 2
codimasta is offline
