RE: Reciever won't work
QWazzy, here's another possible issue to consider. Does your GWS receiver have a little round sticker with an "F" or a "J" somewhere on it, or is there an F or J in the model name on the packaging? There should be--GWS makes receivers on both positive and negative shift deviation, and only the negative shift versions, signified with an "F" designation, will work with a Futaba transmitter. If you got a "J" version by mistake, try to exchange it.
