RE: help with my slo-v
I'm sorry your JB Weld didn't work. Did you mix it correct? It is a epoxy glue and very strong. I had to smear it into the threads of the carbon fibor fuselage. The thin foam tail can crease and weaken and cause it to flutter. I used large stick on aluminum mail box numbers and cut a 2 inch strip to put under the tail mounting bracket and bend to the angle the tail sound be. That solved my tail problems, hope it helps yours.
JB
