Hi Guys this is also my first WB kit this is my progress so far.......
I'll try and keep u up to date, but things are slow going atm
I'm mainly fitting the electrical gear, can any one else confirm that its TOTALLY not a good idea to use the 1 servo for the ailerons
some thing else that concerns me is should i use the engine mount that came with this kit or go for an aluminum one?
Hey like you said in your other post intermidiot... i also want to keep everthing in cowl so cause i already had the .6fx i decided to get this kit and see how it goes with the in cowl muf... might be a bad idea depending on how heavy this bird is.
Greetings from your mates downunder
