ORIGINAL: jjflash
I'm sorry your JB Weld didn't work. Did you mix it correct? It is a epoxy glue and very strong. I had to smear it into the threads of the carbon fibor fuselage. The thin foam tail can crease and weaken and cause it to flutter. I used large stick on aluminum mail box numbers and cut a 2 inch strip to put under the tail mounting bracket and bend to the angle the tail sound be. That solved my tail problems, hope it helps yours.
JB
ohh, i jsut got done taking all the parts off of it so that i could install them on my new parts tommorrow and discovered that the break was not accually the original one, but it was right in front of it and othe edge of were i applied the jb weld.
so it did hold.
