RE: Changing crystals (same channel)
they are not directional, so there is no way to put them in backwards. This is strange. Crystals are usually not that sensitive. You can generally handle them, remove them etc and they still work. I would not want to drop one on a hard floor for example, but under routine handling they normally work OK. You probably have an intermittent problem elsewhere in the system.
