RE: Ailerons backwards
The tiger 2 should have the servos sitting on their sides - but the servo orientation shoudl be 180 degrees away from each other - the last one I helped with was that way. I can't remember if the servo output shaft bothe point towards each other, or away, but my memory says that the 2 servos shouldn't be facing the same direction.
