Old 11-07-2005, 12:59 PM
no1speshal
no1speshal's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: My landing gear is behind the CG...Help!
I will have to try to rake the gear forward. I did not think it was a tricycle config gear assembly because it was a solid epoxy and fiberglass shell, from the nose to the tail section. The only cut outs were on the underside where the wing and fuel tank go and a small opening for an engine on the side. There was a motor mount epoxied in place too, on its side. So, since there were no gear points in the front, I made it a tail dragger. It did have a nice flat spot in the tail to accomodate a tail wheel, so I concluded that was what it was set up for.
Thanks for the suggestions though. Are there any other things I can do? As it is, it will never taxi. So, I will have to do something prior to flight. As far as the gear rake is concerned, the gear rail that I was telling you about, that is right at about 5 inches aft of the leading edge. The wing chord is 13 inches. Needless to say, that will be a hell of a rake! Is there anything else I should consider before I do that?
Thank you all so far for the comments and ideas though. I really appreciate your help.
Red
no1speshal is offline
