I can't tell you how far out it is; only that I notice it when lowering a large bit into a hole to enlarge it. It's not too severe.)
Try moving the table up to shorten the lowering distance required. The lowering of the bit makes the runout greater.
Return it for replacement and take a long bit with you to test the replacement before you take it home! Does Sears still stand behind their products?
