Old 11-07-2005, 03:42 PM
exeter_acres
exeter_acres's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Eliminating flutter with more servos?
kevin, what does the designer recommend???
taking several of the above suggestions.... if the linkage is tight, the hinges are tight and sealed, and the surface is well built... one servo could be enough, (something like a 5955 or even 5945) but it all depends on how the plane is designed.....
Which plane is it, who designed it? who kitted it or is it scratch....
2 servos per aileron are the norm on 40% and similar...but if you do multiple, then you are adding the weight of servos, matchboxes (if needed), linkages and hardware, and potnetially more batteries to power to servos...
not a problem, just things to think about
exeter_acres is offline
