RE: Servo shake
Hi there,
Thanks Mike and Inferno and Thierry.
I use a simple transmitter 2ch. There is nothing more then servo reverse and dual rate.
It's for a hyper 7 1:8 nitro buggy.
The or. config has two standard servo's. No problem with that.
I replaced the steering servo with a strong Hitec digital one. Now when I move only this digital one, the throttle starts jittering. Moving the throttle also causes the digital one to move.
I can't find any metal to metal contact. I also tried it with a setup outside the car. The servo's are okay in my planes.
I also connected both servo's with external power. (Outside the reciever) The only connection through the reciever was the (yellow) pulse.
Nop
I use 4 1,5v penlite bat. 6v With the two standard servo's it's okay.
I contacted the local dealer. He says he has the same problem and can't find the sollution.
Using TWO digital servo's also is no sollution.
sigh
Well many thanks anyway! I will now try what Thierry said. Another reciever like this.
ojzo
