Old 11-09-2005, 06:57 PM
Countryboy
My Feedback: (25)
Countryboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Saito FA-100T Fuel Setup
Jugmaker,
The Ghost is correct in his analysis...the valve I pictured is for a pumped engine. The valve pictured is in fact from my pumped Saito 120 which I just recently pulled from a plane too install a Saito 150. I think the reason the valve is showing up in your operating manual is because the manual covers more than just the 100 T. Here is the link I pulled up to an PDF version and it clearly shows that the pressure valve is for the Saito Fa-300TTDP engine. It appears that your 100 T does not use this valve, which is in all likely hood why it was not included.
Hope this clears up some of the confusion .
http://h1071118.hobbyshopnow.com/Pro...n_cylinder.pdf
Countryboy is offline
