Old 11-12-2005, 03:34 PM
donmcgowan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Saito FA-100T Fuel Setup
On my 100T there was no such valve - simply set up as for any other saito with pressure line off one of the flex mufflers to the tank - the other flex muffler has no vent. I eventually went to a dual crossover pipe system made by keleos creations - works very well -
I strongly suggest you use onboard glo to keep your engine running. I had endless problems keeping both cylinders lit when flying slowly or idling on the ground. After installing the onboard glo, starting and slow flight is amazingley easy. I used an EDL GloLite system - easy to set up and use.
donmcgowan is offline
