RE: Setting Control throws
I don't get it? the main point of a computer radio is to save trim settings for each model, so centered trims for each model doesn't matter. This way were not spending another 2 hours screwing and unscrewing clevises which wear them out and weakens them so every model works on the same trim settings. if we put the equipment in a new plane you just hit reset on that model setting and it's back to center
in most cases you won't ever use atv's or epa. but when you do run across a situation were you do. you'll wonder how you eve got along without it.
" one other advantage for those using non computer radios with many recievers is once set up the trims are all the same"
