Old 11-14-2005, 02:39 PM
2slow2matter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Strange Power Issue - Ideas?
350 Feet isn't going to cause any issue. What size of airplane is it? Wingspan, fuse length, weight of plane? What size prop? What brand. Take the prop off and look on the hub--it should have some numbers. Is it a black plastic prop, gray plastic, wooden? Find out exactly what engine it is as well. More info is needed to actually help you solve your issues. While the altitude isn't an issue, temp might be. If it is substantially colder where you are, then you might be out of tune. However, if your trainer took it off, I'm assuming it was in tune--at least to the ear, or he would have noticed it before takeoff!
2slow2matter is offline
