RE: B&D retracts getting stuck
usuall if you have a flat spot cut into the wire where the screw contacts it and then tighten the screw till it is tight against the wire that sould stop the twisting without having to overtighten.the flat may have to go down about 1/32 to 1/16 of an inch.it should look like a notch
