Old 11-17-2005, 02:37 PM
sbd-5
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: .049 Cox engine RC build
servos torque depends on the size area and amount of deflection of the control surface.you did not specify what size the model is.all servos can run on 4.8 volts without damage some can also use 6 volts.you did not indicate what the mah rating of the pack is.i built a champion fokker eindecker with a cox dragonfly engibne,had throttle and muffler used 3 tower s-10 mini servos and 4 ch mini reciever.with williams bros wheels and a small 100 mah pack weight is 17 oz.flys about 5 minutes full throtle idle is about 4000 rpm but slow enough to landunder power
sbd-5 is offline
