Old 11-27-2005, 12:16 PM
Zippi
My Feedback: (10)
Zippi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default *Using Rubber O-Rings On Cowling*
The cowling on my Edge 540 is showing signs of wear and its only had a dozen flights. The four screws that hold the cowling on has metal washers, I was told to use rubber O-Rings and it would help stop the cracking and excessive wear. I intially smeared epoxy on the inside of all the holes I made in the cowl. My question is, If I use the rubber O-Rings, would you put the metal washer on top of the O-Ring or not use the metal washer at all?
Zippi is offline
