Old 11-27-2005, 05:24 PM
LSP972
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: *Using Rubber O-Rings On Cowling*
RCKen's method is a good fix.
Try this: before you do anything else, glue a CA hinge over each of the holes, on the inside of the cowl, with medium CA. Ensure that the entire hinge is saturated and adheres to the cowl. When dry, open up the screw hole to the same i.d. as your pieces of tubing o.d. Use a washer under the screw head, and you've got a quick, easy vibration isolator.
LSP972 is offline
