RE: do i need a pcm receiver with gas?
You do not need PCM. PPm works just fine. If you should decide to use PCM, set it up with a PPM first and make sure you have no "glitches". If you do, PCM will hide them, and make you think the problem is gone, that is, until it locks out in PCM.
