RE: T-Maxx Transmission Adjustment?
There is a little Prawl or 'shoe' that is attatched to the Primary gear, when it reaches a certain RPM it engages, just like 2nd gear, however there is no adjustment when the Tranny is installed, you have to take the Tranny apart, and UNSCREW the screw that holds the prawl in, littlerally just a HAIR, very slight turns, like 2nd gear, its the EXACT same concept as 2nd gear adjustment is. It could also be your clucth bell, or slipper clutch, so not to say you havent checked, but check to make sure your slipper engages when you want it to, as well as your clutch shoes before you start to mess with the inside tranny set-ups. I had to take my tranny apart aprox 5 times before I got my tranny to engage when I wanted it to. So dont get discouraged, if anything you will get good and fast and installing the tranny..lol
