RE: 4 aileron servos - need TX help
I was bored so I downloaded the JR manual. It looks very simular to how my Hitec worked. Here is the link if you don't have it.
[link=http://www.horizonhobby.com/ProdInfo/Files/JRP9240-manual.pdf]9303 Manual[/link]
The pertinent info starts on the 27th page of the PDF document (or A12 if you are looking at the page numbers in the pages). Basically you need to set the wing type to FLAPERON and inhibit the FLAP switch if you don't want them. I would not use flaps on this plane. Then run the Y's as I described in my last post.
Hopefully a JR guy will correct my if my quick read is incorrect.
scott.
