RE: need a little help
Agent, I'm guessing this is your first plane. OK when you turn left or right you have to also keep giving a little throttle or in some cases full throttle, it is normal for a plane nose to tip down in a turn. The outlaw uses the turning speed of the motors to turn so if you stop giving it throttle and just turn it will turn too deep and go into a spiral dive, I flew the OutLaw for a long time and liked it, good little first plane. So next time your flying try this, when your ready to turn move stick the direction you want to go but don't hold it there, just move it back and forth some, this will help you get used to turning without diving, also keep about half throttle going the whole time your turning. One more thing if you use full throttle and full turn it will dive out of the turn. remember also always fly about as high as a telephone pole and don't fly when it's windy
Good Luck
