RE: Found good speed measurement software
Post #1 is pretty clear in where the placement of the red and green lines should be the data line, but what is not shown is that it dosnt matter what data line you choose to analyse, they will all give you the same result - try it, you will soon see you get the same number. The ones further to the left however will give you a higher error than the ones further to the right. So you basically want to pick the clearest one furthest to the right for the best result.
