RE: Midwest Extra 300xs Build
A Little bit more build time this evening and I am almost done with the first half of the wing. After installing the aileron wire tube(rolled paper), I glued on the trailing edge sheeting. I continued with the leading edge, wing tip and center section sheeting. I will have a little sanding to do on the seams and ends before completing.
