whiplash pipe mount
I took a different approch; I took a block of maple and glued it between the servos, Tapped it to the size required and screwed a custom machined mount in place.The mount it self is an old alum modeling knife handle, Threaded the shaft to fit the tapped hole and the other end drilled a hole to run a tie-rap around,,Metal to metal was ellimated by using a piece of silicon slipped over the tail pipe of the tuned pipe. I turns out to be a very stong mount
