IceJay
Howard is NOT much on details[>:] but!
The nose MUST be higher than the tail (or it won't take off), if you have seen the various videos of Howard's Stryker, you will see this.
I will also say, where Howard's thrust line is even lower mine, his Stryker (once balanced) flies even better than mine does.
The lower thrust line coupled with the Motormax 400 XT, make this thing fly the BA!!S
OOHH and Howard Glassed the top and bottom of the fuse between the stabilizers ( think of a square piece of glass), because he did this, he was able to use wire ties to hold the LG on ( also having a stick epoxy ed the length of the fuse helps too)
