Are there 'standard' switch assignments?
Not sure about changing HELI switches, but all of the switches in ACRO can be assigned to anything as far as I can tell. Not sure if they're the same but I was able to relocate the switch for THR-CUT and IDLE-DOWN, but then moved back to it's normal location since a 3-position switch worked better than two 2-position switches.
