RE: Basic
I have a question. The manuvers (some) show a dotted line (means inverted right?) well then why on a reverse 1/2 cuban do you get points taken off if you don't pull the 5/8 right after you go inverted, actually you might get a zero? Example, I flew my first IMAC last year and had done the manuvers as I understood them by looking at the arestie drawings, pull 45 degrees, roll to inverted, the drawing shows equal distance between the 45 degree start, to the 1/2 roll and the same distance inverted before you pull the 5/8 inside loop. If you look at the drawing it shows about 5 lines between when you roll inverted and when you pull the 5/8. But that is wrong it shouldn't have the dotted line after the 1/2 roll. Does anybody else see it the same as I did?
