RE: My A-10 Warthog Project
Andrew,
Good news on the fans. That should save you a few dollars. If I can figure out a way to do it, I'll try to get a weight on everything so far. It might give some idea of where it's headed. I debated the bellcrank set up as well, but decided to go ahead with it. Someone else built it that way and didn't have any trouble, although one servo per control surface is best.
Keep the questions coming. I'll answer what I can, and others will chime in, I'm sure.
Paul
