New Whiplash Flies from launcher
Whiplash Specs;
1. JR-8411 servos moved outboard 3/4 inchs using AIRWILD
inverted servo arms with heavy duty 4-40 steel pushrods.
2. Elevon hindges cut open on the underside and sealed with
BLENDERM (3M product) waterproof tape.
3.Tank cell bottom removed and SULLIVAN TP-8 tank installed
with a DUBRO cinder bronze clunk.
4. JETFIRE engine with precut header and modified pipe
using 2 degrees right engine thrust.
5. Battery is a Lith-Ion 850 Ma. pack with 5.7 volt regulator.
6. Prop, APC 9-8 until engine is broke in then will try an
APC 8.8-9.75. Fuel is the new MAGNUM 20/20. (good stuff).
