did the servo's used to work with that receiver?? has your tranny switched itself over to pcm modulation?? also, some receivers and speed controllers don't work in certain combinations, maybe your receiver is not compatible with your tranny. also, some synthesised trannies don't work when the same tranny with a crystal module in works fine. try a different receiver with the servo's and see what happens.
