8103
Danny, I read your pasted instructions on the dual elevator setup, this may sound stupid, but you refer to one on channel 3 and the other on channel 7. I am using a 6 channel 236EZ PCM. Does it matter which channels I use? Also, If I wanted to make my ailerons work as flaps, can I do this with this reciever and run dual elvator servo setup? If so, which mix, which chanels. thanks in advance.
