Weston Magnum - Destroyed on First Flight!
got mine today and no instructions..i think i can pull it off anyway.
need the cg. as per above tells me distance but is that from LE at the fuse side measuring back? describe where the servo mounts are made to go pls. and the suggested thows for flight on surfaces......after 28 years building i think with the above info i got it covered.. and now i must fin a 8x9 prop somewhere...never used one with pitch larger than dia.
thanks
joe in ky
