F20 and dual aileron servos?
I am rebuilding a DC F20 and am just starting the wing. I was thinking of using two aileron servos for more precise aileron control,but since the ailerons are already pretty short, I am not sure it is worth it. My old F20 has a single servo. If two servos was suggested, would a hitec hs81 be ok, or should I stick with a pair of standard 3004's? Also, if I go the dual servo route, should I place each servo in the middle of each aileron? On my Dago, they are near the end nearest the fuse, which to me doesn't give as much leverage compared to being in the middle. thanks.
