RCU Forums - View Single Post - Using Two Receiver Batteries
Old 11-26-2002, 08:00 PM
martinjpainter
martinjpainter's Avatar
Default Using Two Receiver Batteries
Hi,
I have received an e-mail asking me how I wired the retract servo with a separate battery pack on the Corsair.
The answer is to use a Y-Lead. Remove the red pin from the plug (opposed to the sockets) of the Y-Lead and either tape it up or protect it with heat shrink. Then simply plug the Y-Lead into the retract channel on the receiver (which only has two pins). Then plug the retract servo into one of the Y-Lead sockets and the other battery pack into the other Y-Lead socket. If you require a switch (very advisable) then connect the switch between the Y-Lead socket and the other battery pack.
