Pattern Aircraft Alignment
I think the general idea is to have the thrust vector equal and opposite (aligned) to the total drag vector so that there is less pitch change when the throttle is advancing or retarding. The presence of a draggy landing gear would require that the wing be mounted a bit higher. A streamlined gear or retractable gear would allow the wing to be mounted a bit lower.
