more speed
how about changing the prop on the plane you have and see what happens. easy and cheap. the 46fx should turn a 9x9 about the same rpms. takeoffs and vertical will suffer but top end should improve quite a bit. You cant have it all. A light plane with lots of thrust and high top end speed would be nice but you have to give up one to get the others.
