RE: Diamond Dust-Landing Gear
Cyclic:
Have had the same thoughts, using a nose retract up front with small strong mechanical servo setup and small strong wire hold offs at the wing tips behind the CG. Bob's centered racilng wheel thought has also be in consideration. Been a lot of years since I have done a wing thing, their side profile is so small I probably would put it into the ground in short order. Still, a good project for this winter after the AC is flying well. (I hope) Bro # 119
