RE: Morris Tomhawk ARF
Well generally, the wheel retracts to the rear and the control rod for that is also on the rear. Well I had the whole thing facing forward. So I took the retract apart and reversed it. The wheel retracts to the rear but the rod is on the front which goes to the servo right behind the fire wall. The control rod between the two is only about 1 inch long. But it works very well.
