RE: Matney Animal Zoomer
Mine is about 70% finished....Wings are sheeted and ail are cutted out, i will put 1 servos per ail. Will use the little hs85.
I'm putting a Jett Q500 in it. The firewall is not hard to glue in. It's not a beginner plane, you heve to built it all the way. I will not use any landing gear. I'm still not sure if i will glass the wing too or put monokot on it....
BTW i dont know if you see alot of glass fuse in your life or maybe the one you get was not like mine, but the fuse is close to perfection. No pinhole, not too heavy, i wish all the df kit i had over the years was like that....
