answer
thanks for the ideas. I normally try to start with the simplest things first then go from there but now I need some more ideas on where to look to correct this. It is not bad enough to warrant me sending it in , but just a little annoying at times.
Both models are on aero. If engine is idling and I move the ailerons in either direction the engine will slow down. When I move the ail stick back to neutral the engine will go back up to previous rpm.
I am not using any mixes, none.
Fred
