RE: The Badius Owners Club
Airbourne
Its a shame you did not like the people selling the Seagull PC9 its a nice aircarft, fly's well, even better with retracts.
Carlf
Sorry if I have missunderstood you but I have the idea that the master Tx on the system you use is not on a sellf cetering switch, when no switches are activated the master Tx should have operation, when the spring self centering switch on the master Tx is moved forward against the spring the slave Tx has control, the trims on both Tx's should be co-incident to prevent massive control differential on trasfer, nothing worse than switching over to half throttle and opposite aileron or elevator trim.
Mike
