ORIGINAL: Crash-D
That sounds great i was actually thinking about the Tower tuned but i heard that the muffler fell apart alot. Could this be easily solved by just adding another nut to the end of the muffler screw or is there really a problem there??
Darion
Tower is not the only two piece muffler that comes apart. I suspect the mufflers expansion from heat may break the bolt rather then the nut backing off. Do not over tighten. They are cheap but a better solution is Jett or Ultrathrust tuned mufflers. A little more money but durable and more performance.
