RE: Panzl 35% Arf Marathon Build
Yup. Thanks.
Right now I have the standard DA muffs... was wondering if I should send 'em back for some compacts... I'll think about it.
So to get this straight... you left the fron of the motor box on and just recessed the firewall back inside it?
Also, my cowl is not mounted, so I was wondering what the approx position of the motor is on yours for a starting point... did you use 10mm left and centered vertically, or does it have to be high on the firewall?
I think I might get some Forgues Research stand-offs... they can be made with thrust angle built in and they don't have the weight that plate at the back. Not sure yet!!!
Jason
