ORIGINAL: buddude8
for speed not very good. that engine i dont think will go over 10,000 rpms. i think the 1.20 is in the 9000-9500 range. sometines bigger is not always better. im sure bob27 will chime in on this
Yep, exactly. You wouldnt want the 120L on the nose here. It will go over 10K a bit, but its not an rpm engine. Designed for aerobatics, scale use with big props.
The best Jett has to offer for the Toni is the SJ-90LX-T or BSE-90LX-T.
LX configuration (high timed) with the Toni/Minnow muffler extension set.
Install an APC 11x8, 11x9 or 12x7, 12x8 and hang on.
(the T engine turns about 400 rpm less than the LX without extensions, but will carry more prop - unloads great in the air)
Bob
